Hi all, A simple question to you people with AL-KO ATC Trailer Control. When you connect the 13 pin plug into your 13 pin socket ready for towing does the green light flash on & off or does it stay solid !!!
Because it can confuse the self-test done immediately on connecting - with handbrake on, no further movement of the operating cable is possible so the ATC can't check that it'll move.xtrailman said:Why do you have to release the handbrake before connecting?
I don't release mine sometimes until last thing.
RogerL said:Because it can confuse the self-test done immediately on connecting - with handbrake on, no further movement of the operating cable is possible so the ATC can't check that it'll move.xtrailman said:Why do you have to release the handbrake before connecting?
Just experience - as I usually use a mover the handbrake is usually off when I connect the 13-pin electrics - but the odd time it wasn't then the ATC couldn't complete it's pre-check until the caravan had been towed forward.xtrailman said:RogerL said:Because it can confuse the self-test done immediately on connecting - with handbrake on, no further movement of the operating cable is possible so the ATC can't check that it'll move.xtrailman said:Why do you have to release the handbrake before connecting?
I'm not sure that's true, do you have a link?
I'm not sure that's true, do you have a link?[/quote
I've had ATC for 7 years and never consciously thought about the handbrake position.
The Al-ko manual is silent on the handbrake.
I usually hitch up secure the stabiliser release handbrake and then plug in.
Roger's point is very valid and logic says he is correct.
The ATC has to go through a pre programmed self test. How can it do this if the handbrake has been applied?
Dustydog said:xtrailman said:RogerL said:Because it can confuse the self-test done immediately on connecting - with handbrake on, no further movement of the operating cable is possible so the ATC can't check that it'll move.xtrailman said:Why do you have to release the handbrake before connecting?
I tested connecting the ATC with the handbrake on.
As expected it made no difference to the start up, and gave a green light on both occasions.
Also no mention of taking the brake off in ALKO instructions, in fact it shows the HB on.
http://www.al-ko.co.uk/edit/files/handbooks/atc-handbook.pdf
JohnJ_5040720 said:Having completed several trips with our New caravan fitted with this system, it dawned on me that I wasn't seeing this light flashing or hearing the "self test" like we did on the hand over.
I thought that it was the car battery that powered this, but have discovered that it only works if the 12 volt power button is on in the van.
Now that I make sure this is on, it all seems fine.
Is this right?
