Al ko shock absorbers.
May 18, 2006
587
14
I have ordered a pair of shock absorbers for my Bailey Indiana. Does anyone know if the holes are pre drilled on the chassis and how easy are they to fit. Any details of how they fit from the chassis to the suspension would help me.
I hope they are delivered tomorrow morning and if they are easy to fit I will get them done before I leave tomorrow lunchtime.
Graeme.
Jul 15, 2005
2,175
Hi Graeme,
The holes are always predrilled in the AL-KO chassis - they are a standard fit in Germany and the chassis is pan-European - and you aren't allowed to drill and AL-KO chassis anyway - so the holes are there.
The instructions should be self-evident.
I know of a comprehensive step-by-step photo-guide to the replacement of AL-KO shock absorbers on the German Eriba web-site. The pictures are self evident, but you'll need to understand a bit of German - let me know if you want the link
Robert
May 18, 2006
587
14
If you could send me the link so I can have a look at it, that would be great. After looking under the van I can now see the holes in the chassis but I can't see how the shocks attach to the hub/suspension.
Graeme.
I've got the dampers on the present van and have swapped them from the last few vand when we change
Its very easy to fit them
There is a rectangular rubber bung under the suspension arm
The bootom bracket is in 2 halves-a bit like if you put your hads back to back.If you imagine the fingers back to back together they go in the slot and then the backs of the hands together moves the fingers apart and into the space inside the slot
If you known what I mean !!
May 18, 2006
587
14
Thanks everyone. I have downloaded the technical borchure from Al ko and the job looks OK to do.
I ordered the shocks direct from Al ko last week and the website said 5-7 working days for delivery. That would have given me plenty of time to fit them. When I chased up the order yesterday Al ko were apparently on holiday last week so my order was omly despatched on Wednesday. It has not arrived at my local depot yet. My last chance is to collect them tomorrow morning, fit them and set off for France early afternoon!
Graeme.
Graeme.
Bon Voyage
Jul 15, 2005
2,175
Hi Graeme,
The direct link is to http://www.7elche.de/Touring/Daempfer/ and the owner reported that it took him 20 - 30 minutes per side - including adjusting the length of the damper stroke
Have a great vacation. Robert
Rob just had a look at the link and sorry to say its not the Alko chassis that we know and love!!
Couldn't understand the bit about adjusting the stroke as all you do is push the damper in until its level with the hole in the chassis.Something was lost in translation I think
Hopefully Graeme has got his bits and set off to France with them fitted.
Regards
Jul 15, 2005
2,175
Hi John,
No, that's a real AL-KO chassis not the bent tin-plate most people have under their caravan. It's made from heavy duty galvanised steel and is still in (custom) production by AL-KO for the current Eriba Touring caravans.
The stroke adjustment is needed for this caravan because the mounting plate is in a different position.
But the job is still the same - offer up one AL-KO shock and do up two nuts and bolts.
And as you say, hopefully Graeme is now underway in France with a rather better controlled caravan
Robert
May 18, 2006
587
14
Thanks everyone. I picked up the shocks from a depot on Saturday morning at 08:00hrs. I then fitted them in about 3/4 of an hour, packed the rest of the van and set off for France about lunch time. After touring about 1000 miles in the last fortnight I have been impressed with the stability of the van with the shocks fitted. A well spent
Sep 24, 2006
57
Hi..
This is something I have been considering for a couple of years now, but to be honest aperthy has got in the way.
So as a person who has towed the same van with assumedly the same towcar both with and without the caravan shocks and has mentioned that it was
May 12, 2006
2,060
I can't be 100 % sure on this, but I think you have to have them fitted in Germany before you can have the tempo 100 Km/Hr sticker. If that is the case I am sure it has been proven that they add to stability !!!
Val & Frank
I didn't notice any difference with the Oklahoma because I fitted them as soon as I took delivery
I already had them available and they are doing more good on the van than in a drawer !!
May 7, 2007
361
Hi Folks, Fitted mine today took me about one hour 20 mins. The only problem I had was that I had the Powrwheel motor mover fitted last week and it was right smack bang in the way. Had I fitted them before it would not have taken so long.
Regards
Graham (Ponty)
