Hi all,
we went to a rally this last weekend and I found a new (to me) way of lining up the two Alko units, firstly position the car and caravan so that the heavyist axle wheel lock can be fitted and fit the lock, then drive the car forward with the one wheel locked until the second unit is lined up and fitted, low box on a 4x4 gives a little more control and obviously this method is only used on grass, the wheel only skidded a few inches on the wet grass, I would have left a bigger mark in the grass by jacking the caravan up and as it was the rear wheel it had less weight on it as the unit was parked on the crown of a hill and the car a little lower. A similar effect may be to run over a small piece of plywood with one wheel and allow it to skid on that, this way most sufaces should allow fitment without jacking or damaging the tyre or suface.
spj.
spj.
