Alko tow hitch... does it need a special tow ball on the car?
Jan 16, 2010
28
Hi, saw an old caravan listed on preloved today which has had an alko tow hitch put on it for safety... my question is does that need a special sort of tow ball on my car? Mine is standard...
Thanks!
Oct 30, 2009
1,542
hi, in theory no as all towballs are 50mm the alko hitch will fit all balls. HOWEVER wether a alko hitch has enoough clearance between the hitch and the body work of the car is another story providing there is a least 25mm of clearance once the hitch is fitted on to the ball it should be ok.
if not alko do a ball that sits farther out from the tow bar mount giving more room.
the main thing about using an old ball with the alko is that is has to be absolutly clean with no sign of damage, grease or rust as this WILL contaminate the friction pads.
ok colin
3,538
1,364
If the Al-Ko tow hitch is one of the AKS ones that has the stabilising function then it MUST only be used with the special towball or a Swan neck type.
Download the document: "Correct Use of Towballs" from this AL-KO web site:
http://www.al-ko.co.uk/support-aks.asp
It is unsafe to use a standard ISO towball.
They all use 50mm balls but that's not the problem; the issues lay with having sufficient clearances both static and articulating.
Dec 14, 2006
3,205
As John states, we had to replace our standard towball when we got a caravan with an ALKO hitch. You can buy a bolt-on Alko towball for not very much on ebay. If you look at them you will see they have a narrow neck immediately below the towball. If the ball is painted black then sand off the paint coating with a very very fine abrasive paper.
