I have tried to remove the wheel lock to allow me to move the caravan to it's winter position, and could not remove the lock. It was left with the black rubber cap fitted, and the key turns to the unlocked position, but the barrel will not remove.I thought that, as it it icy outdoors then perhaps the barrel has frozen in position. I've tried lock de-icer, without success, and my next thought was the hair dryer.
Has anyone else had this problem? How did you solve it? Should I lightly grease the barrel to keep out moisture in the future?
As I've not had the caravan for long, I've only fitted the lock a couple of times, and have wondered how to fit it when levelling ramps are required. This is usually on (relatively soft...ish) grass, and using the jack doesn't seem overly save, even with the opposite wheel chocked. I use the plastic stepped ramps, and can imagine the wheel moving down the ramp when the brake is released. Am I missing something?
Paul
Paul
