another question re fitting ALKO shocks
Nov 5, 2006
805
I am about to buy & fitt the above to my van that is fitted with a mk 1 powrtouch move. I have heard that this mover poses problems & has to be moved to the back of the wheels, involving doing away with the spare wheel carrier.is this correct?
Feb 28, 2009
493
Tony,
You may not have to move the mover but I believe someone is doing a kit to move the wheel carrier further back and thus retain it.(It may even be Powrtouch themselves).
Regards Jim.
Nov 29, 2007
28
I also have a Mk 1 Powrtouch fitted to my Jubilee Envoy (2007)and was told by Powrtouch that I would not be able to fit shock absorbers. I can not really see the reason why, because according to the Alko Specs and Technical data the space required in Fig 5(a) for dimesion D is 52 - 75 mm. I have measured the distance between the chassis and the Powrtouch and have 73 mm available. Could someone tell me the exact dimensions of the shocks please, becaus I do not want to order them and then find there really is not enough room. Many thanks!
Nov 5, 2006
805
Thank you for your reply's I'm still in a dilema as I am picking them up tommorow & do not have time to contact Powrtouch & as dorsetfly says I also have 70mm between mover & chassis as required according to Alko tech data
Thanks td
If I remember correctly, I think that Powrtouch made more than one version of the Mk1 Mover. I think that they made one called a Euro model, with a seperate gear box, that would allow space to fit Alko Shocks.
Feb 16, 2009
1,144
Can you fit the shocks on a Ace Firestar with a Truma s mover fitted in front of the wheels, as l am interest in going down this road.
NGH
