AQUA 8 WATER PUMP activates for no reason - any ideas
May 3, 2010
The water pump in my motor home activates for a few seconds every 5 to 10 minutes for no reason - nobody using a tap. No visible leaks. when a tap is used it activates as normal no problem.
Anyone know the answer?
Jul 6, 2007
265
Presuming it works off of a pressure switch,you must have some sort of leak that is dropping the pressure and activating the pump, or the pressure switch is set incorrectly.I had one that you had to adjust when switching from 12v off of battery to 12v with a mains hook up as it obviously didn't like the lower voltage on battery and seemed to work at a different pressure.
Hope this helps.
4,411
Hi Dave,
Such frequent activations points strongly to a leak somewhere.
Other than drips from the pipework, have you also checked the water heater. If its a Truma there is a pressure relief valve that goes through the floor, if it is a Cascade then it will be on the outside wall.
It may also be the non return valve associated with the Pressure switch, If this isn't locking off properly than it may be allowing some water back from the high pressure side back into the water supply pipe.
Causes of this type of problem may include a water filter that has broken down and allowed carbon granules into the water pipes, and bits may have become embedded in the NRV seals.
As you have already checked your pipework, then it suggests that the lake may be at teh pressure switch which usually also contains a non-return valve in the cold water pipe. If this isn't sealing properly then it will allow a small amount of water back into the supply line, which you wont see because its still in the pipe.
Other things to check, may have a leak through its pressure relief valve, this will the water heater has
Mar 10, 2006
3,274
47
Agree with peter, try reducing the pressure setting, might also be worth checking the surge damper, if one is fitted.
