Hi all just on site and had to go out 3 times to reconnect my blue hose to the aquaroll can anyone recommend any decent connectors to add to my hose to stop them causing a flood to the nice plant feature I'm next too .. 😊
I thought all these hosepipe connections of different manufacture were interchangeablePut a stop end on the hose connection to the barrel float. The hose supplied by Aquaroll has Gardena fittings.
It’s not a non return valve, it’s a water shut off valve that prevents water discharge if the coupling should detach. I use them on the house hoses in the event I forget to shut if the outside tap. Most coupling problems can be cured by periodically lubricating the O ring with silicone oil or grease or replacing it when worn.They are, but they all do a non return valve which is being suggested by Woodentop. Fitted right, if it flies off the water stops.
