- Jun 2, 2010
- 8
- 0
- 0
Hi there, I'm in the process of adding an external socket to my Bailey Ranger GT60. The plan is to use the internal socket at the rear of the van with a plug on the end of the artic cable, so that I can switch the exteranl socket off as and when. The rest of the cable will then be put through one of the ventlaition points so that it can then be attached to the underside of the van and then to the external socket whcih I plan to mount against a base and then attached to the chassis using the pre-existing drilled holes. I will be using 2.5mm 3 Core Artic cable (blue) suitable for 240v.
Has anybody done this type of thing before??? Any Thoughts????
