otherclive said:The powershift is not a torque converter gearbox. I believe it uses double clutches. Volvo offer it in some V70s as Ford went for commonality when they owned Volvo. Looking at my V70/XC70 handbook the variants that use powershift autos have less capability than torque converter autos and more restrictions seem to be mentioned. Fords tech dept are very good and should be able to advise you. Also can you download Owners Manual from Ford website as you can for Volvo?
So if you where going to buy an automatic go for a torque converter as they are better?? So if the ford has two clutches does that mean more expense if the clutch did go? when you tow iv been advised you dont get the same amount of millage out of a clutch as if driving solo, which i would understand as you are making the car work harder. So when it comes to replacing clutches having a manual would be better (not expecting to go through clutches lots)
