Awning for a Bailey 470/4
Mar 26, 2008
43
Have just agreed to the purchase of a used NR awning for the above van. The awning is a 17ft NR Pullman which covers 899-930cm, the Bailey has a 911cm awning requirement. I assume that these measurements are on a like for like basis and this awning should therefore be a good fit. Opinion welcomed and thanks.
Graeme
Mar 26, 2008
43
Have checked the size on the NR website which gives the dimension 899-930cm, and the Bailey sales brochure which quotes awning size requirement at 911cm. Haven't actually measured the
van as in storage. I assume your awning would have been a tight fit but then again I suppose different manufacturers awnings would be subject to some size variation. Will find out if it fits on the May holiday!!!!
if your van is that year listed then the awning size you have got will be a good fit!
I think the same model caravans change abit in size each time they change it, if that makes sence,the models change most years along with the weights.
our awning fit perfect and it was a Dorema
