awning pole tensioners
Sep 8, 2004
101
could anybody please give me some advice on this bit of kit? the poles are 28mm alloy,are they likely to damage the poles? which is the best one to use,i have seen 2 advertised one is the hercules and i think they call the other one the awning companion.cheers folks appreciate any feedback on this.
4,244
Ray
We have an Isabella which needs their Hercules tool to get the tension right.
Best check with your awning maker. Too much tension can be just as bad as too little.
What make and moel do you have?
Cheers
Alan
3,522
1,357
I have the original Hercules designed for steel poles and think that would be a disaster on alloy tubes. I dont know about the one for reinforced plastic tubes but think you are wise in seeking advice.
4,244
Ray
Check the tensioning aspect with Dorema. The Hercules is a powerful tool and used incorrectly could cause damage.
Cheers
Alan
7,357
We have a large Dorema awning with 5 roof poles ( including side ones) and found it virtually impossible to get adequate tension which led to the roof sagging when it rained. The Hercules works fine with alloy poles as the aim is not to get the tension rod tight but just to give the extra *** that is quite difficult by hand alone. The advantage of Hercules over the new one shwon in PC is that you dont have to keep tightening it onto the poles, and with Hercules you just hold the tension whilst tightening the clamp screw.
