Hi everyone need help can anyone tell me the best way to stop my awning skirt sagging tryed suckers velcro dont want to drill press studs in even tryed small clamps.
Thanks very much for the replys tryed these too .Hello David, forgive me if you have aready tried this, but many caravans have a rubbing strip low down which actually has a channel in the underside to take the awning skirt - just like the top rail takes the main awning. so the skirt is unsupported only when it comes to the wheel arch. thread the top of the skirt into this rail and peg the ends out tight and it may solve your problem.
The skirt should have eyelets along the bottom edge. Peg down through these, if necessary take them back under the van to get some tension on them. If the skirt is too deep for the van when level, then consider shortening it and replacing the eyelets - this is quite easy to do and you can get replacements from most accessory shops.
