Awning storm straps
Sep 11, 2007
59
Having been advised not to use the type of storm strap that goes over the awning and could therefore damage the waterproof coating. Has anyone used the tie down kits as available from ebay :
http://cgi.ebay.co.uk/CARAVAN-AWNING-TENT-STORM-TIE-DOWN-STRAP-KIT_W0QQitemZ400070963122QQcmdZViewItemQQptZUK_Campervan_Caravan_Accessories?hash=item5d26166fb2&_trksid=p3286.c0.m14
or the straps available from Screwfix:
http://www.screwfix.com/prods/20481/Hand-Tools/Load-Handling/Thorsen-1-8m-x-25mm-Cambuckle-Strap-Set-2Pcs
Mar 13, 2007
1,750
yes david, every time the full awning goes up and it doesn't make the awning leak well mine never has anyway.
oh B.T.W. a little tip if you do use one and it's a bit windy(the reason for having a storm strap) they tend to flap a bit against the canvas and poles dead annoying just put 1/2 a turn in the strap each side as it goes over the awning and it won't flap and keepyou up all night.
colin
Mar 13, 2007
1,750
colin
should have said I use one that goes over the awning
Jul 21, 2009
101
I always put washing spunges under the strap where it goes over the foof supporting poles. These stop the strap chafing against the canvas
Jul 24, 2009
6
Hi
I found the best thing to do is to use a strip if pipe insulation under each corner. As it is already cut, with the hole in the middle, it sits on the corner superbly, doesn't work its way off and certainly stops the strap from wearing the fabric of the awning.
