Bailey Senator spares (2002 model)
Aug 31, 2005
559
Our Bailey senator Oklahoma is losing bits here and there; firstly the external A/C cover started to flap and then detach itself and now the (flimsy) cover that protects the two-pin power lead for the water pump has disappeared.
Is there a site / catalogue where I can order these replacements?
306
Hi, have you tried your local dealer, as your caravan isn't that old, they should be able to obtain them direct from Bailey!
Several of our local dealers (Stoke on Trent)have the AC flaps on the shelf in the stores
It depends which type of power lead you have but the Bailey dealer should be able to fix you up
C A K Tanks stock lots of fittings and plug/sockets on
www.caktanks.co.uk
www.caktanks.co.uk
You will need to ring them as the site is under construction
