Bailey Unicorn Problems
May 31, 2014
6
18,515
I have a Bailey Unicorn Valencia Series 1 purchased 3 years ago second hand, during a recent weekend away it was noted that there was a crease on the main body above the door. After visiting a local dealer I am informed that this is a known fault with the Bailey and that the best action is through my insurance.
Is this valid considering that it would seem to be a design defect
937
Without knowing the exact age of the van and whether the warranty was transferred to you, then it is difficult to know what to advise.
Also whether the van was purchased from a dealer or privately.
Taking a very general overview and the fact that it was second hand and that it is now 3 years into your ownership, then going through the insurance would seem to be the best way, and probably quicker than protracted arguments with dealers and Bailey as to whose fault it is.
Also you have no way of knowing how the van was used prior to you buying it.
5,404
I'm puzzled?
What insured peril has occurred to cause the damage?
From what you say this is an inherent latent defect and one to take Bailey to task.
Insurers do not pay for design defects or product failure.
May 31, 2014
6
18,515
Thanks for the comments
The van was purchased from my local dealer second hand whilst just 1 year old
I have received a reply from the insurance company who have decided that it as there are no other signs of damage then following the insurance policy wording it is either manufacturing defect or general wear and tear and as a result is not covered by insurance.
Leaving me with a number of options chase the dealer, chase Bailey, challenge the insurer or pay for the repairs myself.
Discussion has now also commenced with the dealer with their response being it should be an insurance repair and not their direct problem. The suggestion of them not supplying goods fit for purpose was immediately rejected (not really a surprise there but worth a try).
Looks like Bailey or paying myself.
5,404
Were you and/ or dealer present when the Insurers engineer inspected the caravan?
Do you have a copy of the insurers engineers report?
Why does your dealer think it is an insurance claim?
Do you have legal expenses insurance attached to your caravan insurance policy?
I and a few others have been involved in this type of issue and believe me the cards are stacked against you.
You need to find an expert in caravan construction who can explain technically the cause of your problem.
Once the precise causation is established we can then look at the options for redress that may be open to you.
4,373
Hi
There are immense difficulties in trying to get this sort of issue resolved. Whilst the Sale of Goods Acts (SoGA) theoretically apply to all retail sales including second hand items, the fact a product is in a second or more ownership complicates matters considerably.
Liability for such issues when proven always follow the contract of sale arrangements, and with caravans it is almost always the case that you have your purchase contract with a dealer not the manufacturer.
The manufacture only get involved if you make a claim against the manufacturer's guarantee, which is a contractual arrangement, but it is governed by the T'Cs of the guarantee. This would only apply to you provided you and the manufacturer agreed to transfer the remaining guarantee when you purchased the caravan. If you did not complete the transfer documentation then the manufacturer has no liability whatsoever to you.
Even if you did complete the transfer of the remaining Manufacturer's guarantee, the guarantee does not cover the value of the caravan, only those points specified in the T&C's
Your only redress would be through SoGA, and you have to bear in mind that whilst SOGA is a powerful piece of consumer legislation, its purpose is to provide a fair resolution when its tenets are breached. So you need to bear in mind some important points.
You tell us the caravan is at least four yers old, It is well into its expected life expectancy, and SoGA recognises that products don't last for ever.
Remedys through SoGA are only expected to return the customer to the conditions if the product had not be come defective. So you should not expect to gain from a remedy.
The conditions a caravan might experience are quite variesd and can be quite harsh, consequently the extent or value of repaires to older caravans may be quite limited.
You tell us "this is a known fault with the Bailey". Just because a fault arrises does not necessarily mean it is a design failure (as per SoGA). As a generalised point, if a product has a design fault, then a substantive number of examples would demonstrate the same fault, and in this case whilst some may have shown it not all have, so a claim of design failure is unlikely to succeed. Consider how likely is it that such a 'design fault' could have gone four or more years before revealing itself?
It's more likely materials or workmanship failure would be the case. but proving in your given circumstances, I suspect would be nigh on impossible.
For a start As Dusty has pointed out, you would need to find a competent independent expert who would not only be prepared to give a signed written report clearly stating the faults were inherent in the design or were present at the time of purchase, but also one who is prepared to stand up in court to swear to the accuracy and methodology of their report and findings. I suspect that your "local dealer " would not be prepared to provide such damning evidence in writing.
Another big problem you will have is the fact the caravan is second hand. Whilst you may be able show evidence to convince a judge you have not any opportunity to abuse the caravan, you cannot have the same confidence about previous owner care and attention. They may well have taken the caravan to extreemes of conditions that might have predisposd the caravan to the damage you report.
What dealers tell you must be accurate. but they are not obliged to volunteer any information, becasue in English Law the buyer must be aware or " Caveat Emptor". As a potential buyer it is your responsibility to ask all relevant questions and to acertain that the product you are thinking of buying is fit for your purposes. Do you have any evidence to show that you asked the seller if there were any known or hidden defects with the caravan, and the dealer's responses? Because if you did not ask, the dealer is not obliged to tell you!
By all means talk to the dealer about it. I don't think you will get a FOC repair, but you might be able to swing a deal such as dealer pays for parts and you pay for labour or vice verca. I am certain tring to use SoGA would be an up hill battle with little chance of success. I susspect you will spend more money and time for no outcome, and you will almost certainly sour your relationship with the dealer. I think you'd be better biting the bullet and paying for the repair and putting it down to experience.
5,404
I fully agree Prof.
You will recall the Avondale case which went through all the hoops and was rejected by the Financial Ombudsman both in regard to the claim against the Insurer and the Credit Card Company.
We then had Travelling Rooster's Elddis with similar creased panels to this Bailey.
Sadly the cost of proving a case can be prohibitive in relation to the actual cost of repair.
