Check out the Aldi website for a £60 portable satellite dish, and caravan security devices. http://www.aldi.co.uk/uk/html/offers/58_6007.htm
Since the BBC/ITV launched the "new" "Freesat" system on May 6th, the word "Freesat" ought to be reserved for the new type of receivers (currently only available from Comet/Currys/John Lewis & Argos).Yes it is a Freesat system and will recieve the majority of channels available on terrestrial freeview with the exception of the CH5 channels until later this year.
There are also a lot of channels available that you will not find on Freeview or FreeSatfromSky as well
I use two Freesat systems at home and one in the van when required.
If you want to recieve the HD services you will require an HD receiver and TV.
That was very thought provoking but I lost it a bit there Chris,Since the BBC/ITV launched the "new" "Freesat" system on May 6th, the word "Freesat" ought to be reserved for the new type of receivers (currently only available from Comet/Currys/John Lewis & Argos).
The receivers from Aldi/Maplin/Lidl & other Satellite equipment suppliers (that have been around for quite some time), are FTA receivers. (FTA= Free to Air).
Both the Freesat and FTA receivers receive EXACTLY the same program channel signals from the 28.2E satellite (commonly, but erroneously, known as the Sky satellite). The only significant difference is that the "Freesat" ones also "automatically" tune into another transponder from 28.2 that provides a 7 day EPG that is integrated with the program channels; whereas the FTA ones can only display "now & next" (if the channel chooses to send the data!). The Freesat receivers have also been designed so that you automatically get your correct regional program.(FTA ones have all variations available for you to choose at will).
The designers of the "Freesat" specification have also done their best to provide a "plug & play" product to suit the less technically minded. FTA receivers vary considerably in their ease of use.
This all applies to both Standard Definition (SD) and HD ones with, currently, one exception; ITV HD can only be viewed on a Freesat HD receiver, not a FTA HD one; but it is anticipated this will change in the not too distant future.
