battery charge
Jun 8, 2010
98
Hi Jamie,
The text book way to do what you ask is to remove the battery from the caravan and take it home and connect a Ctek battery charger which adjusts the voltage / amp requirement of the battery. Charge the battery on a wooden board - not a concrete floor.
Its a bit of a pain to keep removing the battery, but at least you know the battery is in tip top condition and the Ctek will make sure of this.
The xs 3600 is a good all rounder - and usually charges up the battery in about a week for a 110A/hr, depending on how good the battery is, and what A/hr.
There are more Ctek chargers that take less time to charge a battery - but they are more expensive.
The Ctek is designed so that you can leave it permantly connected to the battery - it does the rest.
