battery not charging
Mar 29, 2009
had caravan pluged into mains at house all winter but now the 12v in caravan not working seems battery not being charged by the mains i have tried 2 batteries and the 12v just drains in a couple of hours any ideas how to fix this problem would be appreciated thanks
4,462
Niel,
with no disrespect intended,but without being able to test the various components it will be very difficult to diagnose your problem accurately on the forum.
It would be best and safest to have it checked out by an electrician.
Mar 10, 2006
3,274
47
niel
I would check the output of the charger/PSU. Also check both 12v fuses, and mains CBs.
I would not recommened having the 240v power ON all the time, it enough to charge the battery up every month, sometimes more often if the weather is very cold.
Aug 14, 2008
49
hi, had the same problem with my freestyle....appears that there is a fault on the charging unit, check if its an NE 143M, if so this known at Nordic who are the makers
Feb 15, 2009
300
Neil had the same problem with my Swift Charisma it was the charging unit that was knackered got it replaced with the fusebox (luckily under warenty )
hope this helps
Duggie
May 25, 2008
771
Slightly different, topic but we managed to drain our battery completley, left the CH pump running for 3 weeks. Question is I don't seem to be able to get the battery back to full charge. It shows 3/4 on the caravan meter, and when I have the battery connected to the charger at home in the garage it just seems to be continually on charging mode !! It is a 120Ah battery (2 year old )how long should it take to recharge ???
thanks
Jul 25, 2007
293
Neil, sounds like you have cooked your battery by keeping it on charge for long term. No rechargeable battery will long survive this - hence why I would never use a docking station to listen to my iPod. With a 12v lead acid battery you should not fully discharge either, but like all rechargeable batteries you should always let it discharge to a significant level before recharging - ie don't even just plug it in once a month as has been suggested. Leave your caravan lights on over night once a month and then recharge.
Pity there is no real alternative, but I hate rechargeable batteries because of how easy it is to wreck them just by using them the way that it is convenient. At least unlike an iPod you can replace the battery in your caravan.
Jul 25, 2007
293
thanks
draining a 12V lead acid battery completely causes the metal plates inside to collapse. You have ruined your battery and will never get it to recharge. Chances are even with the meter showing 3/4, if you go to use it, it will fail almost immediately. Sad to say but it is a trip to the battery dealer for you.
4,160
1,890
Contrary to some advice, with a correctly designed "smart" charger leaving it connected continuously is the best treatment you can give your lead acid battery.
Some chargers/controllers fitted to vans are anything but correctly designed. Certainly those on older vans had no multi-phase charging or load side voltage regulation. These used to sit at 13.8 volts boiling the battery and should not be left connected after they part charged the battery.
So whether leaving it connected or not solely depends on what kit is fitted.
Returning to the OP's question: because other batteries are flatted whether the original battery is wreaked or not is a side issue. The problem is something is drawing too much current, far too much.
The cheap device shown in the following link is a bit of kit we should all carry in our tool bag. It enables you to systematically measure what current each fuse is carrying and with this and a modicum of thought you will quickly identify what item has gone wrong within you 12 volt system and is burning up your stored power. With this device you remove the fuse being investigated and fit it in the device, it then functions as normal and the current flowing can be read by pressing the button.
http://www.maplin.co.uk/Module.aspx?ModuleNo=217879
May 27, 2006
22
hi neil do you have a motor mover fitted as i had a simmilar problem with my battery failing to hold a charge for long until i disconnected live lead from mover now it stays fully charged regards john
Mar 10, 2006
3,274
47
As i understand it 13.5volts will not boil the battery, but 14.5v will, hence the reason for 13.5 PSU in a caravan.
Further it is not required to discharge a lead acid battery, prior to charging.
Mar 10, 2006
3,274
47
Frederick
Your mover should have had a isolator switch fitted.
Some movers have been known to activate from external interference.
May 27, 2006
22
Frederick
ray thanks for that i will get it checked it was fitted before i bought the van regards john
Mar 29, 2009
thanks for ur comments but i not have a carvan mover fitted,i have even tried fitting a set of jump leads from my car to caravan battery everything runs fine but once jump leads disconnected caravan battery discharges in less than 1 hour
