Bedroom sliding doors problem
Nov 6, 2025
15
Hi,
looking to see if there is any advice from the community.
Our 850 Elegance Grande has two sliding doors into the rear bedroom. Both doors have dropped due to the screws holding the track to the ceiling working loose.
I have sorted the screws that are above the door 'hole', but cannot get inside the central pocket to sort the screw there (basically adding extra screws to better support the load).
I really don't want to disassemble the entire pocket (there are a lot of panels involved). It does look like the glass mirror ought to be removable as there is a cut out behind that would give access into the pocket and allow for rail maintenance, however it appears that the mirror has been glued as well as screwed to the wooden panel.
If anyone has experience of getting inside the pocket or suggestions on removing the mirror I'm all ears.
Thanks in advance for any suggestions.
