Hi IanHi
I had a Bosal detachable towbar fitted to my BMW X5 in June 2004 when I came to use it in June 2005 I found that it had become loose ie you could move the ball in and out a little bit, it was duly retightened but came loose again after just one outing, having taken it back to the fitters again they have replaced all the nuts and bolts with the nylon locking type, they have tld me if it comes loose again it must be the fault of my caravan which is a Bessacar Cameo 325 single axel nothing too heavy, so to sum up I dont know if this is a common faults with this type of towbar or not.
regards Ian Craig
Have Bosal fitted to Mercedes for 5 years towing van and car trailer , no problems and was less than half the price of Brink or mecedes fitting!!!!!!!Hi Garry
When this current awful weather subsides I will make an effort and get under the car and fit the tow ball, I still find this a bit of an effort and usually only do it once at the start of the caravan season. It does sound like there is an issue with these tow bars, I could literally push the ball in and pull it out by about half an inch. THe fitters told me on the first retighten that every nut and bolt on the system had come loose, scarey to say the least, I wonder if there is a complaints rout via Bosal, as my fitters have now washed their hands of my problem.
regards Ian
Bosal Detachable Towbar: Hi I promised to report back on how my detachable towbar was getting on. After having it come loose and retightened twice last year by the fitters, the third time the fitters replaced all the nuts with the nylon lockable type. Well I have just refitted the tow bar, having forgot to check if it had come loose after our last outing at the end of last year and can report the the towbar is as solid as a rock. So if you are having trouble with the Bosal detachable bar coming loose get the fitters to change the fixing nuts to nylon lockable type.Hi Garry
regards Ian
