break away cables
Nov 5, 2006
805
I'v read that there are 2 types of breakaway cables, one designed to clip direct to the mounting plate & 1 designed to be looped back on its self the difference is the design of the clip If the either one is used in the wrong way it can break off before the hand brake is engaged fully
Mar 21, 2008
364
Hi Tony,
As I understand it, the breakaway cables are all the same and are intended to be clipped onto a bracket on the towbar.
If they can't be clipped onto the bracket then it is acceptable to loop the cable through the bracket and clip back on itself.
If there is no bracket then it is acceptable to loop the cable round the towbar an clip back on itself.
I may be wrong!
Nov 29, 2007
667
Hi Tony,
I may be wrong!
Indeed you may!
