My new breakaway cable is longer than the original and if it goes from the towbar direct to the brake lever coupling it touches the ground. At the moment I pass it through the A frame cover to "use up" a bit of the slack but this doesn't seem right as it's not direct. Is it acceptable to shorten the cable with a loose knot or loop in it's length to take up the slack?
Cheers , Wes
Cheers , Wes
