I've just bought a Dell laptop and hopefully will be using it when I go away on sites.
I'm with BT and they have a scheme called BT Fon where you can register and join. This allows others who are in the scheme to use part of your bandwith when in your locality. When you are away from home it allows you to connect to a member who is local. It seems a good idea and it's free. I see that to use a WiFi connection on C.C. sites is 15p per minute whereas if you have BT as your ISP and join BT Fon it doesn't cost anything within reason. Depending on which Option you are on you get free minutes, I'm on Option 3 so get unlimited.
On top of the Fon scheme there are BT Openzone Hotspots you can connect to.
Option 1 customers get 250 minutes and Option 2 get 350 minutes per month.
This is all new to me so until I go away next month to test it out I'm not sure how good it will be. One thing I do know though, theres no way I'm paying 15p per minute :O( I'm not that desperate :O)
Anyone else on this system and what do you think of it?
