Hi there,
I have been the unfortunate owner of water ingress in my 2005 Clubman 475-CK. I have a what is now a large damp patch on the washroom ceiling above the sink. I initially thought the water was coming in from the join on the roof where the rear panel joins. However, after having this 'professionally' sealed it is still leaking. However I beleive I have now found the cause of the issue and I strong advise all owners of Clubmans 2005 to present to check their HIGH LEVEL REAR BRAKE LIGHT!
I unscrewed mine a few weeks back and found no mastic what so ever around the light. What is happening is the water is running behind the light and into the hole where the supply cable goes through. This hole is far far bigger than the cable and there is no watertight grommit or mastic present at all, just a crappy rubber shroud protecting the cable.
This cable goes into the polystyrene sandwich in the roof and the cable runs in a trough. The water is running into this trough and as the polystyrene is water proof, the water is running along it like a stream! It then comes out from the light in the washrooms unit and is staining the roof lining. No I have to also replace the whole roof lining too - not a happy bunny for a caravan thats just 4 years old and cost £16k
It's now in for repair to be sealed up there too and I frankly find this yet another disgraceful and shoddy workmanship in the caravan industry. I'm under no illusion that Lunar Caravans are the only damp caravans out there as the whole industry is rubbish.....except for one of course who actually seems to be able to move forward!
I have merely put this on here to warn other users of my issue as this brake light should be sealed by Lunar and isn't. Check your's before you suffer the same experience as me!
