Calor gas 'handwheel' connector
Oct 20, 2010
60
I have a Propane Calor Gas regulator which has a hand wheel to connect it to the gas bottle...(Saves faffin' about with spanners that you can never find! ) used for the BBQ at home. Does anyone know where I can obtain a 'handwheel' connector (i.e. Without the regulator). for the caravan, or would it be OK to use the regulator in addition to the 'built-in' gas regulator in the gas locker.
Hope this makes sense......
Thanks in advance for any help given
4,023
1,764
No it would not be "OK"; it might be safe but it almost cetainly will not pass sufficient, if any gas.
Only ever use one retail regulator. [ There are industrial systems where two or more regulators are used in series but not in our caravanning world.]
Nov 28, 2007
490
12
18,685
Dav1e said:
Brightmore, not quite sure if I'm on the same wave length here but have a look at http://www.thegaslowcentre.co.uk/?gclid=CN6jk9LEvqcCFcJP4Qod90I5_Q. I have these fittings fit to my caravan as I suffer with Arthritus and have difficulty gripping. They do a Propane easy fit hose that just connects to your requlator and then you simply connect is to your gas bottle without the use of a spanner. Dave...
I have the same problem and use the same solution. The Gaslow connector has a rubber seal (replacable) which I think helps alot.
