Cameo 600GL
Hi,
Need some help / advice. We are totally new to caravans.
We have bought a Bessecar Cameo 600GL
I am trying to figure out what type of pipe I need to attach to the outside of the van to get the waste water from the tapes into the container.
There is 3 pipes that go from the sinks / shower to a housing that's around 3" around.
Any ideas / advice would be appreciated.
Van is 1997
Just pop caravan waste pipe into amazon and it will come up with all you need πŸ™‚ make sure you get the right size as yours is probably narrower than the standard today. Welcome to the forum and nice van.
Hi,
Took another look at the van. It's a super pitch connection / waste outlet. What should I use / need for this?
L
[hide][/hide]
lydser05 said:
Hi,
L
It's 75mm on the internal diameter
WoodlandsCamper said:
Are we talking of a tourer or static caravan? 75mm diameter is getting to domestic size. πŸ™
The Bessacar is a tourer and given its age will probably be the smaller size but needs checking before buying.
