Cameo 600GL
May 23, 2017
Need some help / advice. We are totally new to caravans.
We have bought a Bessecar Cameo 600GL
I am trying to figure out what type of pipe I need to attach to the outside of the van to get the waste water from the tapes into the container.
There is 3 pipes that go from the sinks / shower to a housing that's around 3" around.
Any ideas / advice would be appreciated.
Van is 1997
Aug 23, 2009
3,167
Just pop caravan waste pipe into amazon and it will come up with all you need :) make sure you get the right size as yours is probably narrower than the standard today. Welcome to the forum and nice van.
May 23, 2017
Thanks Martain
Would I measure the inside diameter of the housing for the pipe or the outside?
May 23, 2017
Took another look at the van. It's a super pitch connection / waste outlet. What should I use / need for this?
L
May 23, 2017
[hide][/hide]
lydser05 said:
L
It's 75mm on the internal diameter
1,819
WoodlandsCamper said:
Are we talking of a tourer or static caravan? 75mm diameter is getting to domestic size. :(
The Bessacar is a tourer and given its age will probably be the smaller size but needs checking before buying.
