I fitted the Maxview Semitronic mounted on the roof about 5 years ago and have transferred it between 3 vans now
I carry a tripod and dish back up in case trees are in the way after using common sense and first telling the site reception that we would very much like to watch Sky TV
They will then usually(so far always) tell you the best pitches for clean line of site of the satellite
I have only needed to use the back up dish 2 times in 5 years due to full site etc--not counting the times its been on loan in France to other campers
I find it much better than using a seperate tripod as the digibox can be installed at home and the dish is aimed from inside the van which is great when its raining
If in doubt about the pitch I can power the digi box up from a small inverter and check line of site before lowering the steadies
Its true and a valid point that you do have to lower the dish in conditions such as today but then I've seen many tripods blown over--including mine !
I chose the Semitronic because it is mounted on a pole that is attached firmly inside the van thus taking the strain off the roof
Hope that helps
One slight drawback with the Semiktronic is that it doesn't like cold weather so if its windy and at freezing or below it won't lower unless you stand on the bed and warm it up via the Heki roof light using a hair dryer
