Car rear suspension
Jul 17, 2014
8
Car rear suspension too soft on Mercedes w124. Any help would be great. I have been told that 'spring adjusters might help.
3,946
Hello Machuche,
Welcome to the forum.
Car manufacturers, especially the up market brands spend a lot of time and trouble to adjust the suspension to suit their target market. Provided the loads you add to the car are within the manufacturers specification, the suspension will almost certainly provide you with the safest combination.
Again with the top marques, they now have some very clever Electronic Stability Programs, which use sensors that are calibrated and set up to match the ex-works components. Tampering with suspension settings may compromise the ESP's and actually produce some unwanted results.
Even i you add spring assistance, you do not change the maximum loads you can apply, they remain exactly the same as described in the cars specification.
If you are unhappy with the cars suspension, the first thing to get checked is if its already overloaded, then if anything is worn or broken. Spring assistance must never be used to correct an out of speck or broken suspension.
Jul 17, 2014
8
I measured the noseweight this morning and it is 110kg which is 40kg more than it should be so will this change when I redistribute the load? I will have to move the gas bottles into the caravan to get the correct balance.
Feb 3, 2008
3,790
Yes, you will need to redistribute the load as per basic rules. However the gas cylinders need to stay upright in their designed location. Do you need to carry both cylinders, or will one suffice?
See here and here
Jul 17, 2014
8
One would be OK but is this normal having to move stuff around to get the balance? Is the car at fault or is it the caravan? I am sure I am not alone in this but would it happen with a brand new outfit..........car and caravan?
Apr 7, 2008
4,909
What method or type of gauge did you use to measure your nose weight ? also what make & type of van have you got ?
Jul 17, 2014
8
Hello
The Caravan is a Swift Challenger 400SE 1994 and I bought calibrated gauge which cost about £28. They had a cheap £8 one as well. Sorry but I am 12 miles from the van.
3,946
Machuche said:
Hello
First of all 40Kg is a massive overload and is dangerous. I have towed many caravans and I have always been able to achieve the desired nose load for the combination, either by redistributing payload items, or by adding ballast. I have always kept the gas bottle(s) and battery in their designated places which is a essential requirement for safety. One one occasion I had to empty the front lockers except for the gas bottles, but otherwise I have never been stumped.
With a 40Kg overload that would show up with virtually any measuring device, but frankly non of the currently available retail gauges (even the ones that claim to be calibrated) measure nose weight in the way it should be measured:-
[ol]
[*]Load your car and caravan with passengers and luggage exactly as if you are about to set off on your trip.
[*]Use a level (horizontal) piece of ground big enough for the coupled car and caravan.
[*]measure the vertical height of the hitch from the ground (EU Regs say it should be between 350 and 420mm measured to the center of the ball) If its out side of these limits then something is wrong.
[*]Chock the wheels (both front and back) of the caravan and uncouple it from the car.
[*]set up the nose weight measurement device to support the caravan hitch and make sure non of the steadies or jockey wheel are touching the floor and release the handbrake.
[*]Now adjust the noseweight gauge to set the tow hitch to exactly the same height that you measured.(I'll bet you can't do this)
[*]Only at the correct height will you record the true nose weight.
The height of the hitch is important as the force it produces varies with the height of the hitch. So as non of the retail nose weight gauges allow you to adjust their height, they cannot measure it accurately. Also as the compress with increasing load it all becomes a bit of a fudge. With regards to calibration, Unless you have the calibration details i.e the degree of error report, the calibration is of no value. If you search this forum for 'Nose weight' you will find a massive amount of information, but buried in it you will find how much error of reading some of the retail devices have been shown to give.
The CC and I recommend using a pair of bathroom scales with a length of wood to give you the correct hitch height. Another approach is to raise the the scales on the caravan steps and phone books to get the right height. Some forum members have produced their own adjustable H frames to sit on bathroom scales.
You current overload is dangerous, on a number of counts. The first is the additional load increases the friction in the over run ram of the hitch. This means when braking the caravan may not compress the overrun ram enough and thus the caravan brakes will not be correctly applied AND the cars brakes will have to handle more load than they are designed to take. Secondly the under pinning of the car where the tow bar is fixed will be put under more stress that they are designed for. The static load is not the problem, its the dynamic loads created when towing which multiply the static loads by many times. This may compromise the structural integrity of the car and tow bar.
It is also illegal to overload the tow coupling.
Jan 31, 2011
316
A few years ago I had a Volvo 850 estate fitted with self levelling suspension
When returning to the car & van at Exeter services a policeman greeted me saying you have got a lot of weight on the backend of the car :eek:hmy:
I explained to him that the suspension had sunk whilst parked & that as soon as we start moving it will pump itself back to its proper height.
So I jumped into the car & drove round the lorry park a couple of times by which time the suspension had returned to it normal position.
I thanked him for his concern picked up swmbo & carried on to Cornwall ;)
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
cefdef
