crazyguider said:How do you remove it from the window? We have one with a snapped runner as oldest sprog was too lazy to loosen it before closing! Oh can't work out how to unscrew them. Thanks
Damian-Moderator said:crazyguider said:How do you remove it from the window? We have one with a snapped runner as oldest sprog was too lazy to loosen it before closing! Oh can't work out how to unscrew them. Thanks
Not all screw to the window surround, newer ones slide into a receiver fixed to the window surround and window.
If you look at where the window stay is fitted to the window surround you should see a small hole in the plastic slider, use a small screwdriver to push the locking tab inwards and slide the stay up and out of the receiver.
The new one just slips in and locks into place. The same applies to the window end.
tenpole said:
Caravan arms on both sides of centre window have failed. Not a good design, far too flimsy.
When you had said this I thought you were referring to a different styling arm. I went to Southeast Caravans in Whitstable yesterday to buy two new arms. I had the old one with me, held it up against the pack and thought it was exactly the same. Only today when I went to fit them I notice there were no screw holes on the latch part.Damian-Moderator said:Not all screw to the window surround, newer ones slide into a receiver fixed to the window surround.
