Caravan Cleaning
Dec 8, 2009
Hi
I have a Bailey caravan and it has black streaks (don't they all) my problem is that even using Fenwicks neat, the black streaks are hard to remove, any other products or idea's better?
May 20, 2007
36
Hi Peter
I use Auto Glym caravan and motor home cleaner and a good car wash solution and that always removes the black marks, just make sure the van is wet before you spray it on and don't let it dry as it may leave a dull mark that then needs to be polished out.
HTH
Trev
Jun 11, 2012
1,533
33
19,685
Hi Peter . try Asda , they sell a good car shampoo for just 70 pence and I have found this very good for removing the black steaks .
Also Mr Sheen is another one to try but after a wash
I must advise that if you use the Asda shampoo wax afterwards .
I hope this helps Sir Roger
5,396
Muc off and/ or neat Fenwicks usually works for me.
Try and give the Bailey a good waxing; I use Autoglym. Thereafter the streaks are easier to remove.
As a real last resort , against the rules, I have used WD40 and it works!
Cheers
Dustydog
