There is quite a bit of movement when the door is closed on my Abbey Stafford 1990 between the door and the door seal, where would i be able to get a new seal and are these easy to replace. Allan.
Allan, you can get a new seal from Seals Direct , google for the website.
Replacing is fairly easy except that you may have to take out the door flyscreen to get to the metal protective piece at the bottom of the door, which has to have the rivets drilled out to remove to allow you to replace the seal, then be re riveted in place and flyscreen replaced.
