Caravan Fridge
Jun 20, 2017
9
My Quattro FB has just had its service. The fridge works fine on gas and mains electric but not 12V. Although I expect 12v is used mainly for towing, and if its not working and the journey is short its not too much of an issue.
Would you get an electrician to check it out or a caravan service centre? Bearing in mind, i was going to be charged £70 just to see if the fault could easily be found and then the repair on top of that
Thank you
8,824
12v is only used for towing and the cars engine has to be running. Modern cars with smart alternators can cause problems. One check could be run engine with full lights on, and fans for a/c then see if fridge works. Has your fridge worked okay before? Wiring from car to fridge can drop voltage if it’s not suitable enough.
This might help. It’s not an uncommon problem.
5,074
Thank you
The caravan need so be connected to the car with the car engine running for the 12v feed to the fridge. If you have a car with a Smart alternator then it gets a bit more complicated.
