It'll need the matching satellite receiver and dome control box within the caravan - it should be possible to get all Free-To-Air (FTA) channels - the TV would connect to the receiverI have just bought a caravan with a Maxview Satellite dome, it looks like a NASA dome
My question is can you just connect a normal TV to it and get satellite channels or does it need some subscriptions or other stuff
Grateful for any advice.
It has a Maxview box inside the caravan that operates the dome and scans for channels.It'll need the matching satellite receiver and dome control box within the caravan - it should be possible to get all Free-To-Air (FTA) channels - the TV would connect to the receiver
Please see my answer to RogerLSome TVs are built with satellite decoders. If yours has that solves one issue but leaves the need for the dome's control box.
You need to identify what you have & what you have not got in regards to this system.
Edit: with the improved digital terrestrial TV signal cover, its arguable that spending a lot on satellite TV here in the UK is cost effective, IMO. I does allow you to get your home location programmes.
[ I have a satellite set up, a basic manually directed dish one but it is only taken now to a few "difficult" locations.]
What is the output from the Maxview box?Please see my answer to RogerL
If I need any more equipment than the current Maxview box I don't think it will be worth it.
I agree with the advantage of Freesat when touring - however I retune the Freesat box with the site's postcode as that gives local news and weather.What is the output from the Maxview box?
If its HMDI, then the satellite signal ought to be already decoded and your set accept that HDMI input, which you then select as the TV's source.
If the Maxview box is "Freesat" (TM), then life selecting the channels is greatly simplified, typically using you home post code. Once set, Freesat or even free-to view do not need altering as does terrestrial TV as you move around the different site locations.
We have had the dome and also the satellite dish however we used a SkyHD+ box and then later a Freesat box. You can pick up the Sky Box HD+ box free from Freecycle and use it to watch all the Freesat programs. The Freesat box allows you to record programs.Please see my answer to RogerL
I have done the same, for the same reasons, the point though being made you don't "need" to retune in the somewhat annoying way as can be needed with terrestrial TV .I agree with the advantage of Freesat when touring - however I retune the Freesat box with the site's postcode as that gives local news and weather.
So if I buy one of these from Ebay I can attach that to the Maxview box and then HDMI to TV.We have had the dome and also the satellite dish however we used a SkyHD+ box and then later a Freesat box. You can pick up the Sky Box HD+ box free from Freecycle and use it to watch all the Freesat programs. The Freesat box allows you to record programs.
We connected the satellite signal into either one of the boxes and then used HDMI to connect to the TV. We never bothered with connecting it direct to the TV so cannot answer that one.
You still need to ensure the Maxview Dome controller is present - it's that which lines the dish inside the dome onto a specific satellite.So if I buy one of these from Ebay I can attach that to the Maxview box and then HDMI to TV.
Sky DRX890W HD+ Satellite Receiver Box
The Sky+HD boxes are often on Freecycle for nothing so why pay for it when the eBay seller probably got it from Freecycle. Is it a single or twin LNB?So if I buy one of these from Ebay I can attach that to the Maxview box and then HDMI to TV.
It has a massive dome on top of the caravan and when you switch on the Maxview box the dome makes lot of noise as it searches for satellites. I have just found an instruction page for it and it says to connect the Maxview to a Satellite receiver box. I'm thinking this one should do the job having read the bit about needing a card for a Sky box https://www.ebay.co.uk/itm/40601051...mkcid=28&google_free_listing_action=view_itemYou still need to ensure the Maxview Dome controller is present - it's that which lines the dish inside the dome onto a specific satellite.
If you're not bothered about sky subscription channels, there are "Freesat" receivers around, eg Humax and also on Ebay. I use a Humax Foxsat which includes a hard drive and the ability to record programmes.
