Satellite TV
Jul 21, 2025
7
I have just bought a caravan with a Maxview Satellite dome, it looks like a NASA dome :oops:
My question is can you just connect a normal TV to it and get satellite channels or does it need some subscriptions or other stuff :unsure:
Grateful for any advice.
3,384
It'll need the matching satellite receiver and dome control box within the caravan - it should be possible to get all Free-To-Air (FTA) channels - the TV would connect to the receiver
Reactions: GW91050
3,943
1,688
Some TVs are built with satellite decoders. If yours has that solves one issue but leaves the need for the dome's control box.
You need to identify what you have & what you have not got in regards to this system.
Edit: with the improved digital terrestrial TV signal cover, its arguable that spending a lot on satellite TV here in the UK is cost effective, IMO. I does allow you to get your home location programmes.
[ I have a satellite set up, a basic manually directed dish one but it is only taken now to a few "difficult" locations.]
Reactions: GW91050
Jul 21, 2025
7
It has a Maxview box inside the caravan that operates the dome and scans for channels.
When I power it on it the dome obviously searches the sky by the noise it makes and you can then select different satellites.
Jul 21, 2025
7
Please see my answer to RogerL
If I need any more equipment than the current Maxview box I don't think it will be worth it.
3,943
1,688
What is the output from the Maxview box?
If its HMDI, then the satellite signal ought to be already decoded and your set accept that HDMI input, which you then select as the TV's source.
If the Maxview box is "Freesat" (TM), then life selecting the channels is greatly simplified, typically using you home post code. Once set, Freesat or even free-to view do not need altering as does terrestrial TV as you move around the different site locations.
Reactions: GW91050
3,384
I agree with the advantage of Freesat when touring - however I retune the Freesat box with the site's postcode as that gives local news and weather.
Reactions: GW91050
5,077
We have had the dome and also the satellite dish however we used a SkyHD+ box and then later a Freesat box. You can pick up the Sky Box HD+ box free from Freecycle and use it to watch all the Freesat programs. The Freesat box allows you to record programs.
We connected the satellite signal into either one of the boxes and then used HDMI to connect to the TV. We never bothered with connecting it direct to the TV so cannot answer that one.
Reactions: GW91050
3,943
1,688
I have done the same, for the same reasons, the point though being made you don't "need" to retune in the somewhat annoying way as can be needed with terrestrial TV .
Possibly it's a particularly irritating aspect with me as I have an Avtex TV , that by design could not feature a slower auto tuner if it was specifically designed to. IMO a concept that is totally at odds with the needs of their intended target market, a TV for those travelling about, so regularly having to be retuned. Hopefully something in their more recent TVs they have addressed.
Reactions: GW91050
Jul 21, 2025
7
So if I buy one of these from Ebay I can attach that to the Maxview box and then HDMI to TV.
Sky DRX890W HD+ Satellite Receiver Box
3,384
You still need to ensure the Maxview Dome controller is present - it's that which lines the dish inside the dome onto a specific satellite.
If you're not bothered about sky subscription channels, there are "Freesat" receivers around, eg Humax and also on Ebay. I use a Humax Foxsat which includes a hard drive and the ability to record programmes.
Oct 8, 2006
2,017
701
If you use a Sky+HD box, if it has an expired viewing card still in it then it will work for FTA channels without adjustment. If the box has no card it will show BBC1 London and ITV Central West. You can buy a Freesat-from-Sky card from Sky for a one-off of about £25.
Tip: if you go to the likes of Cash Converters you can get a Sky second room box (does not have recording capability) with remote, mains lead, and warranty for less than £20. If you are lucky it will still have a viewing card in it so will work on FTA channels.
5,077
The Sky+HD boxes are often on Freecycle for nothing so why pay for it when the eBay seller probably got it from Freecycle. Is it a single or twin LNB?
Not sure why you would want a Satellite Receiver box if you have the Maxview control in the caravan. The out cables go straight into the Sky+HD box. Then HDMI to the TV.
Jul 21, 2025
7
It has a massive dome on top of the caravan and when you switch on the Maxview box the dome makes lot of noise as it searches for satellites. I have just found an instruction page for it and it says to connect the Maxview to a Satellite receiver box. I'm thinking this one should do the job having read the bit about needing a card for a Sky box https://www.ebay.co.uk/itm/40601051...mkcid=28&google_free_listing_action=view_item
3,943
1,688
Personally I would get one with recording capability, ideally twin decoders so you can watch & record different channels at the same time. Also IMO keep to selecting a Freesat (TM) unit would be my recommended.
The Humax range take some beating IMO and again used ones are readily available.
Have you checked if your TV already has a satellite decoder, some have? In a caravanning environment avoiding stringing a top box into the bundle of wires and units, if avoidable, is very attractive!
