Satellite TV
I have just bought a caravan with a Maxview Satellite dome, it looks like a NASA dome 😳
My question is can you just connect a normal TV to it and get satellite channels or does it need some subscriptions or other stuff 🤔
Grateful for any advice.
It'll need the matching satellite receiver and dome control box within the caravan - it should be possible to get all Free-To-Air (FTA) channels - the TV would connect to the receiver
Some TVs are built with satellite decoders. If yours has that solves one issue but leaves the need for the dome's control box.
You need to identify what you have & what you have not got in regards to this system.
Edit: with the improved digital terrestrial TV signal cover, its arguable that spending a lot on satellite TV here in the UK is cost effective, IMO. I does allow you to get your home location programmes.
[ I have a satellite set up, a basic manually directed dish one but it is only taken now to a few "difficult" locations.]
It has a Maxview box inside the caravan that operates the dome and scans for channels.
When I power it on it the dome obviously searches the sky by the noise it makes and you can then select different satellites.
Please see my answer to RogerL
If I need any more equipment than the current Maxview box I don't think it will be worth it.
What is the output from the Maxview box?
If its HMDI, then the satellite signal ought to be already decoded and your set accept that HDMI input, which you then select as the TV's source.
If the Maxview box is "Freesat" (TM), then life selecting the channels is greatly simplified, typically using you home post code. Once set, Freesat or even free-to view do not need altering as does terrestrial TV as you move around the different site locations.
I agree with the advantage of Freesat when touring - however I retune the Freesat box with the site's postcode as that gives local news and weather.
We have had the dome and also the satellite dish however we used a SkyHD+ box and then later a Freesat box. You can pick up the Sky Box HD+ box free from Freecycle and use it to watch all the Freesat programs. The Freesat box allows you to record programs.
We connected the satellite signal into either one of the boxes and then used HDMI to connect to the TV. We never bothered with connecting it direct to the TV so cannot answer that one.
I have done the same, for the same reasons, the point though being made you don't "need" to retune in the somewhat annoying way as can be needed with terrestrial TV .
Possibly it's a particularly irritating aspect with me as I have an Avtex TV , that by design could not feature a slower auto tuner if it was specifically designed to. IMO a concept that is totally at odds with the needs of their intended target market, a TV for those travelling about, so regularly having to be retuned. Hopefully something in their more recent TVs they have addressed.
So if I buy one of these from Ebay I can attach that to the Maxview box and then HDMI to TV.
Sky DRX890W HD+ Satellite Receiver Box
You still need to ensure the Maxview Dome controller is present - it's that which lines the dish inside the dome onto a specific satellite.
If you're not bothered about sky subscription channels, there are "Freesat" receivers around, eg Humax and also on Ebay. I use a Humax Foxsat which includes a hard drive and the ability to record programmes.
If you use a Sky+HD box, if it has an expired viewing card still in it then it will work for FTA channels without adjustment. If the box has no card it will show BBC1 London and ITV Central West. You can buy a Freesat-from-Sky card from Sky for a one-off of about £25.
Tip: if you go to the likes of Cash Converters you can get a Sky second room box (does not have recording capability) with remote, mains lead, and warranty for less than £20. If you are lucky it will still have a viewing card in it so will work on FTA channels.
The Sky+HD boxes are often on Freecycle for nothing so why pay for it when the eBay seller probably got it from Freecycle. Is it a single or twin LNB?
Not sure why you would want a Satellite Receiver box if you have the Maxview control in the caravan. The out cables go straight into the Sky+HD box. Then HDMI to the TV.
It has a massive dome on top of the caravan and when you switch on the Maxview box the dome makes lot of noise as it searches for satellites. I have just found an instruction page for it and it says to connect the Maxview to a Satellite receiver box. I'm thinking this one should do the job having read the bit about needing a card for a Sky box https://www.ebay.co.uk/itm/40601051...mkcid=28&google_free_listing_action=view_item
Personally I would get one with recording capability, ideally twin decoders so you can watch & record different channels at the same time. Also IMO keep to selecting a Freesat (TM) unit would be my recommended.
The Humax range take some beating IMO and again used ones are readily available.
Have you checked if your TV already has a satellite decoder, some have? In a caravanning environment avoiding stringing a top box into the bundle of wires and units, if avoidable, is very attractive!
Thanks everyone
I bought a Humax box from Ebay with hard drive.
Plugged it all together.
Switched on Maxview box and after some whirring it locked onto Astra 2.
Scanned for channels and it found loads.
Just been watching the cricket hundred on it.
We are away in a week so I will see what else it can do
im just considering buying a Maxview ID 65cm with twin LNB. I can fit a dual F connection on the van and pass it through to the sockets inside. If i connect a Humax, or similar to the sockets, will tha be ok my TV does have a satellite connection with inbuilt tuner ?
In theory you won't need the Humax PVC/Receiver if the TV has an inbuilt satellite tuner - but you could connect the dish to the Humax to use the PVC and then connect the Humax to the TV via the HDMI sicket.
I was thinking that with the Humax, i could pause live play and maybe record too. I do intend to just go from the socket linked to the outside socket via satellite wires straight to the tv, but am considering getting something to pause play and record. I have a Humax at home so I thought this may help, what do you think ?
We use our Humax Foxsat PVR both at home and in the caravan - it means anything recorded at home can be watched whileaway, and vice-versa, but does mean more to pack/unpack.
If you're thinking of buying equipment specifically for the caravan it would be easy enough to use cables to make it's use optional - so if you wanted to travel "light" just cable from the dish to the TV but if you wanted record/pause facilities cable it from dish to box and bocx to TV.
