Caravan Mover
Nov 29, 2007
35
Has anyone any experience of using a caravan mover in sandy pitch conditions? The site where we intend to use our mover is sand based for the most part the sand is compacted however there are some soft spots.
Gordon
Jun 17, 2011
826
27
We have a Truma with grit rollers. In one particular sandy spot the sand seemed to lubricate the rollers. The modern metal rollers might be better. Softness is important on the jockey wheel and soft ground can give steering problems.
Nov 29, 2007
35
Thanks I have grit rollers as well, so we will have to see how it goes
Dec 12, 2005
123
Gordon, Whenever I use my "mover" I always try to drive it in reverse, ie. with the jockey wheel trailing. In softish going, if the j/w is leading, it tends to "dig-in" Also I find, as my mover is fitted in front of the axle, the rollers are below the centre of the wheel and are pulling the wheel upwards & tends to make firmer contact with the wheel when driving the van in reverse, the j/w just rides on the surface.
Just try pushing a wheel barrow over a soft surface, then try pulling it, then you will see what I mean.
Tankie
