Selecting lorry/truck setting ect will Only adjust the estimated arrival time & journy times. fastest route wil usualy keep you off B & smaller roads but can still put you in awkward positions if your not carfullHere's some input input Johnny 5.
I've used a Garmin i3 and now a tom tom XL.
On both, I've set them to truck for vehicle preference and fastest route, so that they generally pick routes with no low bridges or steep hills or narrow roads. That is unless there is no alternative.
But as usual you do have to treat sat navs with some caution. Mine was having a hissy fit navigating me round the M6 A34 interchange at Brum yesterday. It just couldn't tell me where to go in enough time even when doing 20 mph on the roundabout. Got it right third time round!!
So treat nav's as an aid rather than an asset and do your home work on a paper map as well, because when the nav dies, you'll need the map!!
Atb Steve L.
Steve I totaly agree with you BUT the lorry truck settings do not take in to consideration the length height or weight of the vehicle in planning a route.The fast / quickest settings do tend to use the m/way main roads there by in the main safer for larger vehicles.I should also add thta, I drive 25'000 miles per annum leisure.
Also when I'm working, I do another 45'000 miles on top of that.
I've used both navs for both aspects of driving and while the instantly noticable feature is an increase in time for the journey taking into account road speeds for trucks, ther are route differences as the truck/bus setting utilises more trunk roads where available and as a consequence of this avoidance of low bridges as trunk roads generally don't have bridges under 15ft 9" high.
Also as said before. One should not assume that tom is god! You do have to use your eyes and brain to determine if you are going down the road or is it a farm track (C class road), that your sat nav has decided is the shortest route.
While I can get to within 10 miles of 99% of destinations using my knowledge of the uk, I do double check on a map to see that I'm thinking of the right route.
I do jokingly call our sat nav's "pratt nav's", purely because they do make mistakes in the directions for instance and to be quite honest if you solely rely on sat nav then you could be called the joke word espicially if you turn into roads that blaitently are not correct. My TOM TOM has tried to send me the wrong way around roundabouts, but of coarse I don't believe it, would you?
An extreme example of people relying on electronics was when I crewed a yacht. It had every electronic gizmo you could think of. But when an electrical fire wiped out the toys, the skipper didn't have a clue what to do, as they didn't have a compass. I had one in my survival knife, which we used to limp back to port. I also made a depth sounder from a ball of string and a weight. The string was knotted every metre to show depth of water as the echo sounder wasn't working either.
So toys are good, but still use brain and eyesight too.
Atb Steve L.
Like I said ME---- GI = Go !!!!!!!!!Not arguing with you steve.Arrogant i maybe, but this statement by you is incorrect.
"On both, I've set them to truck for vehicle preference and fastest route, so that they generally pick routes with no low bridges or steep hills or narrow roads. That is unless there is no alternative."
And lets be honest do we really want new be's to sat navs with all there ilks getting misleading advice?
because putting it politely, the sat navs you mention and indeed all run of the mill sat navs do not avoid low bridges, steep hills or narrow roads.
But As I stated earlier you can download POI,s that will warn you of these things, but still will not divert you around them.
For tom tom users, try "tom tom home" most of these POIs are free.
Appologies there tony,Steve in leo,
I find your last post most offensive as I myself am over your stated age and have been a member of the scouting association for many years as a scout leader.
I would suggest that you stick to the subject of the forum without finding the need to have a go at us members of society that contribute in a constructive and useful way to the education of young people keen to learn a variety of skills.
young people of today have a very bad press, comments such as your do little to help!!
