- Mar 14, 2005
- 10,137
- 940
- 40,935
The supplement contains some quite useful information but one should treat it with some respect as it also has a few misleading passages, even incorrect information.
Page 1 - Mass in Running Order
"Mass of the caravan equipped to the manufacturer's standard specification stated on the caravan weight plate"
There is no requirement to have the mass in running order on the weight plate.
Page 7 - Mass of vehicle in Running Order
Mass in Running Order always includes a 90% full tank of fuel and allows 75kg for the driver and sundry items. If it does not include the driver it is not Mass in Running Order but kerbweight.
It would have be valuable if the guide pointed out that details can also be found in the V5c certificate where it is termed "Mass in Service".
Maximum Authorised Mass (MAM)
It would have been worth mentioning that this is identical to MTPLM.
Page 8 - Towing load limit
"The maximum trailer mass that the car can tow."
This is misleading. It would have been more accurate to say that it is the maximum axle load of the trailer that the car may tow. (The noseweight is considered part of the payload of the car and is therefore not included in the towed weight.)
Page 9 - Caravan/Car Weight Ratio
The guide states that it is the actual laden weight of the caravan divided by the MRO of the car. However, it is normally understood to be the MTPLM of the caravan divided by the MRO of the car. Using the actual figure rather than the MTPLM is a bit meaningless as it cannot be compared with other weight ratios.
Page 11 - "Your caravan's MTPLM does not exceed your car's MTPM"
While this is obviously highly recommended, to my knowledge, there is no legal requirement to this effect.
"Then make sure that the caravan noseweight lies within the 5% to 7% range."
This suggests that it would be unsafe to be outside this range although it is often not achievable with the average towcar and modern (heavier) family size caravan, thus leaving the owner in a bit of a quandary. Applying the maximum allowable figure is usually quite adequate.
