- Nov 11, 2009
- 25,652
- 9,406
- 50,935
My caravan CoC was issued in April 2013, but the Hankook tyres are November 2011 as I suspect the economic circumstances at the time affected sales and supply chains. They are good spec Hankooks with 6mm tread depth left. But having 60psi inflation pressure and the caravan load over two wheel they are completely different to how my car tyres are used. So today's job is to install my side lift jack brackets and then have all three tyres replaced. For around £240 I can have Bridgestone with the added assurance that if I should get a puncture or damaged tyre the spare will be suitable for continued use until replaced along with the undamaged road wheel on life grounds. I wouldn't have a punctured 60psi tyre repaired other than as a temporary requirement for it to be used as a spare for the duration of my trip.
Just for info there are company's that do make specific trailer tyres which are clearly embossed with the required warning "Trailer Use Only". I have previously had GT Radial Kargo ST6000 and Kenda Kargo Pro on caravans and found them to be okay. But they don't make them in my current caravan's size so it going to be Hankook or Bridgestone. R14C tyres.
