Carbon monoxide detector placement
Ours are located by the door. I assume the location has been assessed by the designers. (That might be a joke).
But our van just has the one door. 🤓
CO is almost the same weight as air so it does not sink to the floor, Eego you can fit it anywhere convenient.
However your fire alarm is likely to be a standard unit that detects heat and smoke. Consider replacing it with either a heat only or heat plus delayed smoke so that it doesn't keep going off if the toast gets a bit overheated.
Our fire detector was near the door and had a noise suppression button, so if it squarked when grilling etc it would be suppressed for a few minutes . Carbon monoxide detector was mounted towards bedroom end on wardrobe wall about six foot above caravan floor.
The smoke alarm going off is the usual indication that dinner is ready…….
