I have no water coming from the hot tap have changed the non return valve but when I turn on the hot tap nothing even the pump dose not come on but its OK on the cold tap there is no Microchip on any of the taps
Ray , what caravan, and year might help the forum, when did you use the caravan, when it was Ok.I have no water coming from the hot tap have changed the non return valve but when I turn on the hot tap nothing even the pump dose not come on but its OK on the cold tap there is no Microchip on any of the taps
That sounds like the microswitch in the hot tap has failed - but some caravans had a single pressure witch instead of each tap being microswitched.They are mixer taps and the cold runs fine the pump dose not come on when you turn the hot tap on but it dose when the cold in on
