Never been happy with frost being the cause of mk2 filter housing cracking, not directly anyway.
I I see it yes there is a design weakness at the bottom of the threads in the housing, but to suggest frost is causing the water in the filter to expand and crack the housing at this weak point is to my mind wrong?
Simply the 'filter' is beyond the threads which are in the filters cap, it is also chocker block full of carbon granules which leaves very little space for water to lie, plus the whole filter is circular so any expansion is only length ways so only pushing outwardly on said threaded cap, however inboard end of filter is sealed by a felt pad which is more than capable of absorbing any expansion the little water present can be accountable for.
No, I think the problem has always been the filter is overtightened when fitted, something very easy to do trying to make it seal compressing the dry grippy rubber 'O' ring at the end of the threads. The plastic housing can cope in the summer when it's warm but when it gets cold it's more brittle and gives way under the strain, simple as that!
Solution is coat threads and 'o' ring with silicone grease or if not that, Olive oil, never Vaseline or indeed other cooking oils which can soak into and expand the rubber....and crack the housing! 😱hmy:
And I might add, same applies to toilet holding tank rim seals or they swell, expand and leak!
