carver cascade wiring to pump and taps
Hi all newbie here
I am re wiring my craftsman caravan as the controll panel had burnt out. i am struggling to find a wrring diagram that shows how the whale sub pump water heater and microswicth taps are wired up. any one able to help please
Hi Richie, and welcome to the forum.
Suggest you provide more details about your van and heating model and year. In that way, someone may find a wiring diagram for you
AS JCL has suggested we need a bit more information to be able to identify a wiring diagram.
But I can assure you, apart from the 12V supply that both the pump and the gas side of the Carver Cascade need to operate, both the pump and the heater are otherwise totally independent of each other and share no wiring or control functions.
The caravan is a miracle 134
The 3 green and 3 white wires as well asp the 2 twin cables where attached via the choc block the 2 twins go to taps.
Thank you for the photo and the bit of a description. Of immediate concern is the fact you have two pairs or brown and blue wires which are of course normal mains (230Vac) colours. Because I cannot check first hand to see what they are connected to I have to urge absolute caution and do not proceed unless you are certain of what you are doing.
A pair of green and whites should go to each water tap and when a tap is opened, a micro switch inside the tap should close its contacts to allow power to pump. So all the greens should be connected together and all the whites should be together, so if any tap is opened it should cause the pump to run.
The DIN plug should only go between the heater and its wall switch. 12V Power for the heater is connected inside it's wall switch, and not down at the casting
Because of this uncertainty I'm not prepared to guess at what any of the wires are, and I urge you to only proceed if you are competent and confident working with electrics. Otherwise it would be best for safety to arrange to have the caravan wiring checked and put right by a qualified fitter.
