carver water heater
Apr 11, 2005
1,387
Hi all, hellp for a friend please heater runs off gas and electric,works on gas fine,but the ignition not firing, also no lights on 12volt circuit, could the two be connected?? Any ideas ?? p.s caravan is a Eccles diamond elite !!(1988)
3,587
Hello Tina,
You appear to be describing a Carver Cascade 2GE.
Your description does not make sense, you say 'it works on gas fine, but the ignition not firing'. These two statements do not make mutual sense.
As you go on to say there are no lights on the control panel, I assume you really meant that the gas system does not heat the water.
The mains electric side and the gas side are controlled entirely separately, so it is possible to have hot water from the mains element without the gas being operable.
The biggest clue is the absence of lights on the 12V control. If you have no lights that usually indicates no power.
This could be due to a blown fuse, a switch not set in the right way, a connector worked loose. On a more serious side it could be a faulty wall control or burner module in the heater.
A process of elimination would be needed to identify the cause, and the resolution will depend on the actual fault.
You need to establish if power is actually reaching the 12V dc input terminals of the heater.
Apr 11, 2005
1,387
Hi John L
Thanks for your reply,sorry it was a bit vague but it was relayed third hand, the gas does not heat the water but the electric will, he cannot hear the firing of the ignitor which led him to believe this an electric problem,also as he now has no 12volt lights wondering if its all one prob or two seperate things !!! thanks for your advice will show him your reply !!!
