carver water pump for 1984 compass rallye 2 berth please help!
Apr 23, 2008
20
hi guys just traded my seventies caravan for a 1984 compass rallye 2 berth my old van had a foot pump to bring the water into the van , this one uses an electric pump which i need to buy , it is a carver pump housing, will a new carver/ truma pump fit this housing or not? it looks like a standard pump fitting except the electric terminals are flat thanks for any info from phill
936
Phillip, if you mean the electrical connections are two flat metal strips at the sides of the pump inlet, then you need a Whale Watermaster 881
Apr 23, 2008
20
HI Damian thanks for your advice, i have found out that my housing is actually for a carver comet pump so i have just bought a whale submersible pump from my local dealers and connected it with some standard hose and two spade connectors on the electrics which the guy in the shop fitted for me it works perfectly and im very grateful for your advice thanks !
