cassette toilet hole in top
Jun 25, 2010
22
my thetford cassette toilet has a small round hole in the top.
t appears to be part of the system ,
the toilet works and there is no smell apart from usuall chemical,.
Any ideas what the hole which is for etc or is there a bung missing ,
its about one of the earlest 1990
its 8m approx accross
regards paul
1,649
Can't help with your problem, but by 'eck thats a big hole. How big is the toilet?
mel : ) : )
Feb 3, 2006
696
There is something missing that's for sure.At a guess it's the pressure valve. You should be able to replace it I would have thought. You certainly don't want an hole in it as the contents will escape when you carry it to the waste point !
3,524
1,359
Sounds like the vent hole on the old C2 model.
Go to this web site and download the "vent seal" PDF document;
http://www.thetford-europe.com/web/show/id=51498/langid=42
There is a hole of about 10mm dia close to the button that turns the blade. At the bottom of this hole is a rubber vent seal that used to require regular hooking out and cleaning if I recall correctly.
Make a note of this useful website for all Thetford problems, there is a mine of useful info on it.
Jun 25, 2010
22
many thanks guys
its a bit toilet to take my fat arse HeHe
Jun 25, 2010
22
jtq.
many thanks straight on to web sight sand found that the 8mm small seal missing.
was carefull when emptying it yesterday. no spills thank goodness!!!
thanks for your clear link ,
regards paul vp gloucester
