Change from 4x4 tower to saloon?
Hi
We've been towing with Mercedes ML350 for five years and are thinking of a change. Perhaps an E350 saloon with towing capacity of 2100 kg braked.
Caravan is Swift Elegance 645 (21015 model) with MIRO of 1679 kg and MTPLM of 2100 kg.
Online matching says ok for experienced driver which I am having driven Land Rover towing trailer with tractor loaded as a young man.
Caravan is twin axle with fancy electronics to avoid snaking.
Should I go with E350 or new 4 x 4 ?
ML is seven years old and I'm thinking of getting a brand new vehicle for the first time using a Contract Plan.
Grateful for sound advice
Norman
Forget the max tow capacity for the moment as that is for an 'ideal' trailer, eg a car on a car trailer (with a very low centre of gravity, or the example you gave of a tractor on a trailer which has very low side cross sectional area), and the ability to pull away on a given slope. A caravan is NOT an ideal trailer due to its high sides. What is the kerb weight of an E350 saloon and then do your towing ratios, as the MTPLM at 2,100 kg is relatively high?
There are some tremendous deals available on the Merc GLE at present. MB dealers will match and beat Carwow. The GLE 350 AMG Line is a good un 😉
The factory fit towbar will match your caravan fancy electronics, video here of it's deployment:
https://www.youtube.com/watch?v=QUvSKIyTtuA
I currently tow a heavier single axle Sterling Continental 570 with a larger saloon car, an S Klasse, S350 LWB, and wouldn't consider a smaller saloon tbh. There are only 2 saloons that will tow with such a large caravan, the other is an Audi A8. Just my two pennethworth
Thanks to both for replies. Arranged a test drive tomorrow so see how I feel after that.
The GLE is a great machine and that tow bar is exceptional.
Ive just purchased a new GLE, having already owned 4 other ML's through the years.Didn't plan to change the X5 but the deal was amazing, not only did i get a good discount i also got an extra £6k off for buying on a pcp, which after 1 payment i paid off.
A much bigger car, smoother 9 speed gearbox and quieter too. VED is lower as its euro 6.Lots of toys, active cruise, blind spot 360 camera even side wind assist!. It also has the electric towbar. Tows superbly. Only complaint is some of the quality of the plastics isnt as good in some places and only 2 tie down points in the boot.
The e class is even nicer inside much better dash etc but then is a new car not a facelift. More than capable car and as long as the weights are good and you dont mind the lower driving position then either would be fine.Big downside is the boot, in an estate or 4x4 your load can be higher and easier to put longer items in the car if you need too.
Are you sure your MPTPLM is over 2000kgs as that seems really heavy? I though they were only around the 1900kgs mark?
Thanks very much for your reply Michael. Very informative and helpful.
I'll double check those figures.
Yes - the interior of the E class has grabbed my attention. I'm having a test drive this afternoon so will report back.
Yes - the ML has been enormously helpful as a home vehicle with its large road space.
I'm wondering how much cheaper the E class will be ( or should I say less expensive )
The VED changes in April. Whilst some say if you are buying a car over £45k you can afford the increased VED, some say why pay more tax!!
If you can wait a bit, there is an E Class 'offload' estate due out in September that gives you the 4matic, higher stance and the E class interior.
Michael, what colour and trim did you get your GLE in?
Agreed the GLE is a mid life facelift, but it is a very capable tow car with the 350 having the superlative 3.0litre V6 mated to the new 9 speed box, the air suspension as standard. If you have no need for 7 seats.
Also worth getting is the service plan, no need straight away, but prior to the first due service. It includes AdBlu.
Thanks for that Keefy.
I must confess the lesser road tax of the E class is of interest along with the lesser purchase price albeit on a contract basis.
The estate does make sense though I've always preferred the saloon shape on an aesthetic basis.
Regarding service I will give that some thought but have been very pleased with the independent Mercedes garage at Warrington.
I am also considering how long the car sits on the drive and is used other than for towing the caravan.
Regarding general driving of the GLE the provision of air suspension is attractive as I have heard it does make a difference to the ride.
This is all most helpful in coming to a decision so many thanks again
By the by.... I hear that smaller tyres lend to a smoother ride.
We're both in our sixties now and are keen on that.
Any advice in that regard?
By smaller do you mean taller sidewalls, and subsequent smaller wheel diameter?
There is a difference in tyre size in respect of ride quality. For example my current S Klasse has 19" wheels and air suspension. My mate has 18" wheels with taller sidewall tyres and feels a softer ride. That we can determine the difference speaks volumes.
On the GLE for example the standard wheels on the AMG Line 350 are 20" with option of 21". I took an extended test drive in GLE 's with both wheel sizes and found the 20" were comparable in harshness to my mates S Klasse; not a measured test, but close enough. Whereas the 21" was comparable to my S Klasse with the 19", I'd go for the 20".
The difference with the GLE air matic suspension over my S Klasse is you can set 'individual' in the control unit to tailor the suspension, gear changes to what you want. Giving infinitely more choice.
Depending on what spec you go for, on the Designo line, the seats are also controllable by air inflation to give you a cocoon type feeling.
On your test drive, play with the settings and note the wheels/tyres fitted. A good dealer will facilitate as long a test drive as you want. Go on different roads, A, B, Motorway etc to get a good feel.
Not that I'm steering you, but you might be getting the drift of my choice!! 😛
We went for a Polar white AMG line 350d with the premium plus pack, this gave lots of extras for one price. I added the 21" wheels no difference in ride and they looked better and are easier to clean. Also added the night pack, proper leather, off road pack and the safety pack and of course the towbar. I have a set of 20" which im putting winter tyres on. I have always ordered cars as none have ever have the factory fitted towbar and didnt want to retrofit one.
Didnt go for the Designo as the leather is either porcelain, ( no good for the life we have) and brown which i didnt like.
Delivery time was 20 weeks.
They gave me 2 years free servicing, but i have never taken out the service pack as they have always given me 20% off and i supply my own oil.
Thanks for that Michael.
I'm afraid I did not have a good experience on the test drive in that when Inturned up 15 minutes early for the 3.30 appointment this afternoon I was approached by the manager after a short wait who told me that there was no record of any appointment.
He went off and after a delay said that his colleague had omitted to enter the appointment in the diary.
I was so disappointed in the situation and the casualness of his manner that I decided to leave.
I have now arranged a test drive with another local dealer for Monday.
I did have time while he was checking what had happened to sit in an E 350 in the showroom and was suitably impressed.
Ah well.....
MichaelE said:
We went for a Polar white AMG line 350d with the premium plus pack, this gave lots of extras for one price. I added the 21" wheels no difference in ride and they looked better and are easier to clean. Also added the night pack, off road pack and the safety pack and of course the towbar. I have a set of 20" which im putting winter tyres on. I have always ordered cars as none have ever have the factory fitted towbar and didnt want to retrofit one.
What interior? Always been put off the artico man made leather (vinyl). A mate had it on a E270 and it split on the front seats inside a year, I went for full leather on my E270 at that time.
The night pack on the white is a good look.
Quite like the Brilliant Blue with the two tone black / porcelain nappa leather interior, myself 😉 I have grey/dark grey interior in my S Klasse with Magnetite black paintwork, lighter interiors particularly with a pano roof give the impression of more space. Had a retro fitted OEM tow bar, that was gratis due to delay in supply from MB Germany 😛
How do you connect the breakaway cable to the tow bar? Is a change of breakaway cable to the carabener one required?
WoodlandsCamper said:
See photo in this thread. I got one from W4 to replace the existing one.
Thank you muchly, I'll look at finding it.
This one? http://www.w4limited.com The galvanised one. Much cheaper than the pukka AlKo one :evil:
Went for the black nappa, didnt want porcelain as had oyster in my BM and not matter how much i cleaned it it showed every mark .Colour wise didnt want grey or silver and definitely not black , the Diamond white looked very yellow. At present i still loop around the towball like i have done on all my other cars, although it does have have a hole to clip it to the towball now. I have a BPW chassis so still have the normal breakaway cable which i may change to the carabener type.
Click here for an example.
But, but .. that's a whole 2 bob more 😛
That's what I enjoy about this forum, experienced, helpful people who understand context.
A picture from the day of collection, not so white now 😳 The led headlights are amazing and the active cruise in fog is superb.
I collected the new tow car on Saturday, changing from a large saloon (Mercedes S350L) to a 4x4 (Mercedes GLE350 AMG Line Premium Plus pack with Driver Assistance pack). Went for a stand out colour, Brilliant Blue with nappa leather interior in Porcelain and black. Factory fitted electrically operated tow bar that operates at the push of a button, either in the tailgate or in the drivers door.
Very happy. Just need to get some miles on it before towing at Easter. Just had confirmation of the booking at lovely CL near Bristol we have used before 🙂
I had to change cars recently to cope with the weight of my new van. Seriously considered merc as that was my old car but the dealers by me are poor. I ended up with a Jaguar XF R sport black edition. 3.0 v6 diesel.
Your new toy looks very nice though!
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
frwfrwg
