Changed from Calor Butane to Calor Propane - Can I use same hose?
g1
May 21, 2007
83
I've just exchanged my empty 7kg Calor Butane cylinder for the lighter Calor 6kg Propane. I was told that I needed to change the regulator which I have done. There was no mention of hoses so am I right in assuming that I can use the same hose for Propane that I used for Butane?
Thanks , Wes
936
Presumably you are using a cylinder mounted regulator.
You can use the same hose as long a it is in good condtion.
It should be changed every 3 years at most anyway, preferably annually, or sooner if damaged in any way.
g1
May 21, 2007
83
That's as I thought and the hose was new in April . That's reassured me, so, thanks Damien.
